DV79 frozen menu 3/8
Discussion in 'Blu-ray & DVD Players & Recorders' started by Kurtl, Oct 31, 2005.
Tags:
  1. Kurtl
    Kurtl
    Hello everybody,
    I used to be a happy DV79 owner but since 2 months I'm a little frustrated.
    Normally I bring my old Panasonic DVD-player to our regular home cinema evening to friends together with the panasonic PT AE300 beamer, but this time I wanted to present an extra good picture and took the DV79.
    They don't have any AV-receiver so to be on the safe side I configured everything to PCM downmix and set the speakers to no center/ rear boxes.
    Back home I noticed that the menu freezes at menu "Audio 3/8" and I have to switch the unit off completely.
    So since that time I am restricted to stereo enocoding but I loved the prologicII encoding of the DV79 and really miss it.
    Do you have an idea what to do except sending the unit in ?
    Is there a setting to restore the factory settings so maybe that coud help ?
    Any help appreciated
    Kurtl
  2. per-Sony-fied
    per-Sony-fied
    Jul 24, 2005
    2,305
    +100
    Try holding the stop button down for 4 or 5 secs?
    Designed to get you out of trouble for setting a non compatible progressive signal maybe it'll have the same affect for audio menu.
  3. Kurtl
    Kurtl
    Thanks per-Sony-fixed but that I have tried already with no effect.
    That was also the proposal from my dealer.
  4. Engineer
    Engineer
    Dec 11, 2002
    44
    Cambridge
    Kurtle,
    Please contact Arcam customer support. Tell them Pete sent you.
    The freezing on page 3 of the setup menu is a known software issue that occasionally happens. Fixing it is straightforward, sorry I can't divulge the information on here.
  5. Kurtl
    Kurtl
    Hello Engineer,
    I got a quick response from your colleague from Arcam support and instructions how to reset the player.
    Now everything is fine again and I really enjoy the PLII sound again.
    Thanks a lot for your help :hiya:
