DV79 firmware upgrade needed?
Discussion in 'Arcam Owners' Forum' started by gregeas, Oct 9, 2004.
  1. gregeas
    gregeas
    May 7, 2004
    175
    NYC USA
    +6
    I bought one of the first DV79s to arrive in the US, and it has firmware version 5.0.0. Questions:
    Is it worthwhile to upgrade to the latest firmware? I am connecting via HDMI/DVI to a Panasonic 6UY plasma and via analogue two-channel to my A32.
    Do the upgrade instruction on the audiophilesystems.com website apply to the DV79? I quote:
    This document gives instructions for updating the player software and drive firmware for the various Arcam DVD players. The players covered by this document are:
    • V3 players: DV88, DV88P, DV27
    • V5 players: DV78, DV88PLUS, DV89, DV27(V5), DV27A
    If you have an Arcam DVD player that is not listed above, please contact Arcam Customer Support who will be able to supply you with the correct document.
    If not, where can I find instructions that do apply?
    Thanks.
  2. ihan
    ihan
    Sep 10, 2004
    624
    28
    Stockport
    +25
    Those instructions are fine. I followed the procedure (V5) and everything went ok. I already had the 5.8.0 firmware though, so I can't comment on how much of an improvement it will bring.
    I downloaded the zip file, unzipped and burnt the resulting iso with nero to a CD-RW (or -R would do fine). I'm awaiting a new firmware release to see if they have fixed a couple of bugs still outstanding.
    Regards,
    ihan
  3. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    If you are using a universal/learning remote other than an Arcam one, don't upgrade to 5.8.0. It has a bug where the transport commands (like next chapter) execute twice.
    There is supposed to be a fix in the pipeline.
  4. gregeas
    gregeas
    May 7, 2004
    175
    NYC USA
    +6
    Thanks. I'm using the Arcam remote. But if a new version is coming, maybe I'll wait.
  5. gregeas
    gregeas
    May 7, 2004
    175
    NYC USA
    +6
    I just tried to upgrade the firmware, and I couldn't get past the "bad disk" message. I followed the instructions...nothing doing.
    Any suggestions?
  6. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,523
    Edinburgh
    +1,243
    Try burning the files to disk at a lower speed, sounds like a corrupt disk.
