DV79 Enhanced CD and Zone 2 Problem
Discussion in 'Arcam Owners' Forum' started by Gavlaw1, Jan 10, 2005.
Tags:
  1. Gavlaw1
    Gavlaw1
    I've recently bought an AV300 and DV79 based system and overall I'm very impressed with the performance. However, there seem to be 2 problems (reproduced on my suppliers demo system too, so it looks like a software issue):
    1. If you use the RC codes in the back of the book to programme a remote (in this case a Marantz 5400), the code for Zone 2 simply switches the AV300 to the PVR input - wrong code or software error?
    2. I have the Maroon 5 Songs About Jane enhanced CD and it comes up as a "bad disk" on the DV79. Taste aside, I think this reflects a further software issue (same problem shown in the shop, where other DVD players from Denon etc. had no problem).
    Anyone else seen these problems and is there a fix on the way?
  2. Gavlaw1
    Gavlaw1
    It seems that the DV79 doesn't just dislike Maroon 5, but any CD with a slight mark on it, that other DVDs does not worry about. Any answers from Arcam on fixing this?
