DV79 and 2.1 sound ?
Discussion in 'Arcam Owners' Forum' started by NaimBoy, Oct 19, 2004.
  1. NaimBoy
    NaimBoy
    Dec 11, 2003
    98
    This is probably going to seem a little daft, so let me explain.....
    I'm a hi-fi nut with a Naim system (ooh ooh he mentioned the 'N' word in here... :devil: ) and want to extend it for use in the world of AV. Much as I love the Naim gear I can't justify £2.5k for the DVD5, especially as it doesn't have HDMI !
    After much debate, research and demoing I'm rapidly coming to the conclusion that the DVD79 is a more practical solution. However, there is one more problem... The Naim racks only take boxes that are 350mm deep, which is kind of limiting when it comes to AV receivers !
    So.... the plan at the moment is to buy the DVD player and wait until I can afford the Naim AV2/V175 processor/amp combo. As this is £3.5k it will have to wait a while (to put it politely...) so I was wondering if the DV79 can be persuaded to work in 2.1 mode - i.e. Front L & R and a Sub. From what I can make out in the manual is should be possible - can anyone confirm this ?
    Cheers,
    Mark
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,501
    Edinburgh
    +1,237
    Yes it can. There is an option in the player's menu callled 'Stereo + Sub'. This can be set to the following settings:
    1. 'None' = Obviously turnes this feature off
    2. 'Duplicate' = Sends frequencies below the set crossover point to the main speakers and the subwoofer
    3. 'Crossover' = Sends frequencies below the set crossover point to the sub only.
    The crossover point in the DVD player can be set to a wide range of different settings which should cover most needs.
  3. NaimBoy
    NaimBoy
    Dec 11, 2003
    98
    Thanks Crustyloafer........ :thumbsup:
