I have just bought a DV78 and am experiencing a strange fault. I am getting a distorted output from the analogue line out when playing CDs. I have a NAD T752 amp and am connecting using the CD input. The volume level is so loud compared to other sources. If I use the digital out from the DV78 and play CDs with the DACs in the T752 then the volume is normal and no distortion. This is strange because I actually tested the exact player in the shop before I bought with no problems. I have tried connecting the DV78 to another input on the amp, same problem. Tried different leads, same problem. I have subsitued the DV78 for my old CD player, Philips CD880 all is well. I have even borrowed a friends Myriad CD player, no problem with the amp. Has anyone else experienced problems like this?
I am going to get the player swapped over at the weekend, hope that sorts the problem otherwise I'll have to buy a different player cause I want it to play CDs as well as DVDs. Btw the DVD playback is excellent, no complaints there, also the movie sound is first rate. All this is a little irrelevant if it can't play CDs....that is of course why I chose this player!
