Dv717 Meets Xbox Mediacentre ..let The Transformation Begin!!
Discussion in 'Desktop & Laptop Computers Forum' started by lei179, Aug 4, 2006.
  1. lei179
    lei179
    Aug 8, 2004
    611
    +12
    I was recently contacted by a forum member who saw my Pioneer/xbox hybrid SEE HERE http://www.avforums.com/forums/showthread.php?t=317813 and asked me to do a custom xbmc mediacentre that would fit in with his other AV gear and not look so ugly or make as much noise,so i took the challange...knowing that the dv717 is an ideal donor case i advised him to get one.
    The project details will be as follows.
    Built in wireless controllers x2 with status leds.
    built in DVD remote eye for ease of use on XBMC
    2x Silent fans 80mm
    300gb HDD
    HDTV output/support
    (if time i will add 2x USB ports for keyboard and mouse support)
    XBMC as main dash to allow streaming from pc or NAS.
    Pics will follow the progress so that you can see how im getting on!
    DAY1
    Its arrived (minus one of the feet!!) say goodbye to the ugly XBOX!!
    [​IMG]
    Time to open her up i think!
    [​IMG]
    well some how i will have to fit the xbox in there i will keep this thread updated when i can!!
    Thanks for looking in.watch this space!!
    Lei
  2. lei179
    lei179
    Aug 8, 2004
    611
    +12
    DAY2/3
    Stripped out the 717 case.......
    [​IMG]
    theres loads of room in there!!!
    Got to get the back of the dvdrom bracket cut off to allow the M/B to sit in place......
    [​IMG]
    also the bottom of the case has pressed ot "bobbles" they wil need to be grinded off aswell...let the sparks fly....
    [​IMG]
    Stripped out the Xbox Aswell,removed the bezel from the 717 and will fit it to the xbox DVDrom tray...........
    Remember people always backup the HDD !!! Softmodded already to save time later!!!
    [​IMG]
    Inside of the xbox.now stripped all controller ports and PSU removed,going to have to extend the PSU wires to about 12" to allow for the final placement.
    [​IMG]
    Well so far so good folks now the fun really starts :rotfl: :rotfl:
    Lei
  3. willsy2
    willsy2
    Apr 22, 2005
    643
    28
    Newcastle
    +32
    What programme are you running on your PC there?
  4. scumball
    scumball
    Jan 12, 2004
    6,527
    Harrow - London
    +451
    Guessing that it's a TV input card - windowed on the desktop.
  5. stu_69
    stu_69
    Dec 20, 2002
    213
    Hello mate
    This looks great. How much are you charging for this and would be be up for another build ;) ?
  6. lei179
    lei179
    Aug 8, 2004
    611
    +12
    As Scumball says,its just the xbox running through Descaler.
    Lei
  7. lei179
    lei179
    Aug 8, 2004
    611
    +12
    :D Thanks Stu, customer confidentuality will be used :cool:
    As for another build,my own project is now on hold due to doing this,so it woulb be a while ;)
    Lei
  8. lei179
    lei179
    Aug 8, 2004
    611
    +12
    :mad: DAY 4
    Hit a snag:mad: all xbox dvdroms arent equal so it seems.there a HUGE!! LUMP underneath this Phillips drive!! which means it sits too high,major rethink!!
    see what i mean!!
    [​IMG]
    It covers the internal motor so it will be really tight
    I might be able to cut it off (more grinding!!) but still unure if i will be able to use it.
  9. triplea4uk
    triplea4uk
    Jan 12, 2002
    2,018
    48
    Northants
    +85
    You can cut that lump of it was put there to stop mod chips but didnt seem to ever work
  10. John
    John
    Dec 13, 2002
    11,635
    +3,304
    Forgive my stupidity , could you not use the original DVD drive , unless of course, its broken :D
    I have to admit , I am getting seriously tempted into this sort of project :suicide:
    John
  11. lei179
    lei179
    Aug 8, 2004
    611
    +12
    Jon,you cannot just use any dvdrom,that would just be too easy:) the xbox has a specific type.You can use certain PC ones though.
    Triple,
    Iam going to get it cut today,so fingers crossed the motor dont hit anything in the case.
  12. lei179
    lei179
    Aug 8, 2004
    611
    +12
    DAY 5
    Well after a lot of measuring,cutting and grinding i think the dvdrom will be okay:smashin: Had to make some drastic alteration to it.....
    [​IMG]
    As you can see Major modifying!!.....why did i say yes to this !!! :rotfl:
    also grinded the bottom 'humps' off the case so he motherboard can sit flush
    and the back of the dvd bracket had to go!!
    [​IMG]
    While i was waiting for the grider to cool down :D i extended the PSU wires as you can see they have been lenghtened by 12" to allow for final placement.
    [​IMG]
    Getting somewhere now!!
    I layed out a rough plan of where the motherboard will sit,tried the dvd and it JUST clears the resistors on the motherboard!!!
    [​IMG]
    well that most of the boring stuff done i think,:D just a case of mounting all the bits and getting that bloody dvdrom working!!
    Still waiting for the wireless controllers to show up,but i will be getting on with replacing the LEDS in the case and getting the power/eject board wired up to the case buttons.
    Thanks for looking,next update soon.......
  13. John
    John
    Dec 13, 2002
    11,635
    +3,304
    Thank god for email notification .
    I keep forgeting this thread has been elevated to the status of Audio Visual Sources > Entertainment Computers & Components :D .
    Maybe all Xbox threads should be moved in here . Its not like we play games on them anymore ;)
    john
  14. lei179
    lei179
    Aug 8, 2004
    611
    +12
    DAY 6/7
    Well after all that talk saying the DVDROM would fit ...it didnt!!:eek:
    I couldnt beleive it,when you 'eject' the lens underneath drops down about 10mm causing the dvdrom to jam!!!
    I had to drastically cut the dvd rom bracket out to allow for the Lens movement...not the neatest cutting but you dont see it...
    [​IMG]
    Finally got the dvd rom sorted!! ejects fine added the Bezel from the DV717 to the front of the xbox dvdrom,had to slice the lip off the 717 dvdrom tray so that the bezel can be removed at any time,and then glued it to the xbox dvdrom..
    [​IMG]
    Also fixed the drive into place with some hommade brackets,the crucial bit being the height so that the tray operates smoothly.
    [​IMG]
    motherboard has also been mounted into place,but my camera has run flat!...no piccy im afraid...so not too bad a weekend reallly,still have alot of soldering to do,also made a start on the smoked windows for the controller sensors!!
    Thanks for looking!!
    Lei
  15. lei179
    lei179
    Aug 8, 2004
    611
    +12
    DAY 7/8
    Had a bit of a break over the last few day still waiting on the wireless controllers to arrive,as promised heres the latest installment in this project for those who are taking an interest,thank you its getting a few views now but NOT MANY COMMENTS !!!Come on dont be shy!!:D it also makes me feel this is a worth while task..
    Motherboard mounted!!
    [​IMG]
    Really easy to do that bit:D
    Also made a start on the 'windows' that will hide the RF Receivers!...i know theres a big window already on the front but theres a good reason for using the STOP and PLAY Buttons which will become clear further on in the project!!
    [​IMG]
    Not very clear but it looks really good!!
    Done most of the soldering that i could,i have wired up the P/E board to the buttons on the case,tidyed up the wiring a bit,just waiting for the controllers and i will be able to mount them and extend the receivers!!
    [​IMG]
    Really starting to take shape now,a few cable ties help alot!!
    [​IMG]
    Case eject and main power button all working fine,so i made a start on changing the DV717 leds to blue........
    [​IMG]
    The three Leds that are left will be status indicators for the wireless controllers!!!
    Well thanks until next time i hope you are all enjoying this thread!!
    Lei
  16. willsy2
    willsy2
    Apr 22, 2005
    643
    28
    Newcastle
    +32
    Wouldn't mind a few wiring diagrams for some of the wiring, i've got a spare xbox lying around. I'm getting the itch again, mind you i've still got my son's pc to finish and a couple of mini-itx boards i wan't to mess about with, plus i've promised i'll build her indoors' dad a more up to date PC to use a digital camera on. I'd still like the diagrams, i might do it alongside when i get around to rebuilding the old Suzuki 500 i've got in a hundred bits in the shed :eek:
    I'm really enjoying the build BTW. :smashin:
  17. meggie_dude
    meggie_dude
    Nov 12, 2004
    519
    28
    +25
    OK - contentious point here.
    I realise this is an interesting little exercise here, but I am struggling to see the point of it.
    The xbox technology is well out of date now. As I have found out you can add to its life a little by turning it into an XBMC.
    But if you are going to go to all this trouble with the end game of providing an gaming machine in a Pioneer shell, then why not load PC internals into the box and turn it into a true media centre with if necessary an xbox emulator.
    I hope you don't charge by the hour btw.
  18. lei179
    lei179
    Aug 8, 2004
    611
    +12
    I think the point here is the xbox may well be 'old hat' be will still be the cheapest option when it comes to a media player/server.
    A pc could be put in there very easily,but not at that price.. £50.00 for a xbox £200-300 for a pc.
    Once you add XBMC it becomes so much more than a games machine,my own project was built as just a media/storage/streaming device with the added bonus of being able to play 1000's of mame/emulators.The xbox is one ugly lump which is also noisy as hell,but put it in a nice case add a few silent fans and you have a bit of kit you would be hard pushed to buy at the price.
    The forum member who has asked me to do this has the same idea,it mixes in with your other AV eqipment,and when your running this through your plasma with all your MP3's sorted by album covers aswell as your tv/movie rips the 'WOW' factor still to this day has friends asking "will you do mine?". :eek:
    Lei
    ps.
    In all honesty it has not been that labour intensive,in total maybe only 3hrs so far!
  19. bravogolf
    bravogolf
    Mar 24, 2006
    1,296
    +123
    You're doing a fantastic job, mate. I've got this thread bookmarked and check it every day or so, keep up the great work :thumbsup:
    Edit: oops, ignore the "as" title ;)
  20. lei179
    lei179
    Aug 8, 2004
    611
    +12
  21. lei179
    lei179
    Aug 8, 2004
    611
    +12
    Willsy2: Pm me as i have a xbox resource disc you might find useful.!
    Bravogolf: Thanks for the comments,nice to see someone is enjoying the thread.
    Well controllers have arrived,so i will be stripping the receivers down,whilst watching the footie tonight.
    Lei
  22. lei179
    lei179
    Aug 8, 2004
    611
    +12
    Controllers stripped and ready to be wired up,also done the DVD dongle,ready for final placement.
    Will be away tonight but i will update with new pics soon...
    Quick question, does anybody know of a way to make a really clean 80mm hole in the rear of the case for the fan?
    I used a jewellers saw to do mine but it took ages:eek:
    Lei
  23. craigizmo2k2
    craigizmo2k2
    Jun 13, 2005
    1,867
    Boston, Lincolnshire
    +166
  24. spuddler
    spuddler
    Oct 28, 2004
    385
    28
    +29
  25. scumball
    scumball
    Jan 12, 2004
    6,527
    Harrow - London
    +451
    If you were doing a lot then these are great - I used a 30mm one for a Arcade Cabinet control panel - really easy to use and a great clean hole. The 30mm ones are about £7 though not £90!!
  26. i_hate_you
    i_hate_you
    Oct 3, 2003
    14
    London
    Very interesting, I've got an old xbox and a champagne coloured 717, as mentioned before how much do you want to do mine the same :smashin:
    Great machine the 717 best remote ever
  27. lei179
    lei179
    Aug 8, 2004
    611
    +12
    Hi all,been away for a few days,i havent forgot this thread,:D
    Well almost done really,just waiting for a few 80mm fans to arrive,had a right time with extending the controller 'connect' switches,for some reason they would not work when i extended the wiring....really weird,but i think i have it sorted now.
    I have a few pics of it up and running,and others of the logitech receivers i will post them as soon as i have chance.I'd say its 95% done,just the rear holes to cut and mount the fans and HDD.
    Keep you updated!
    Lei
  28. John
    John
    Dec 13, 2002
    11,635
    +3,304
    Liar ;)
    Got nothing to say to us anymore ?
    John:D
  29. scooby do
    scooby do
    Dec 11, 2002
    2,058
    48
    +95
    Lei first time i have seen this thread, lookin good. Makes mine look like an ugly ducklng!!
  30. ian_c_uk
    ian_c_uk
    Feb 3, 2006
    1,420
    48
    Greater Manchester
    +93
    Nice project, and I have a spare xb so I'm getting mighty tempted to try it!
