DV717 manual
Discussion in 'Blu-ray & DVD Players & Recorders' started by sharkbait, May 4, 2003.
  1. sharkbait
    sharkbait
    Hi all,
    Does anyone know somewhere online that is a good source of technical info for older DVD players.
    My wife seems to have filed the manual for my Pioneer DV717 in the bin. Don't you just hate it when they do that! :mad:
    There's a couple of things I want to check and could really do with info on the 2 SCART ports - which one is the RGB out (AV1 I assumed) and whether that needs to be enabled as RGB). I've had the player for years now, but have only used the s-video out previously.
    Many thanks if anyone can help.
  2. nathan_silly
    nathan_silly
  3. Falconer
    Falconer
    Yep, on page 62 of the manual it says you can configure the AV1 scart output as video, s-video or RGB and that AV2 cannot be set like this. So that confirms your theory.
    I believe you need a disc loaded, press STOP if it has started ,press MENU and go to the "main" section when you will find the "AV1 output" setting...
    :cool:
  4. sharkbait
    sharkbait
    Thanks for the reply guys. Job done.
    Nathan ... not sure which link was the most useful ... :rotfl:
    Falconer ... perfect instructions ... better than the manual methinks.
    The RGB is definitely an improvement over the s-video I was using previously. Many thanks for the advice.
