DV29 multi region hack
Discussion in 'Arcam Owners' Forum' started by Arwa, Oct 21, 2004.
Tags:
  1. Arwa
    Arwa
    Hello the Arcam team or any Arcam Dv29 owner,
    I have just bought a Dv29, but to my surprise it is R2 only. I had a Dv27a before. If I remember correctly, I had managed to hack it to multi region with the remote. Can you tell me the remote hack for Dv29?
  2. cybersoga
    cybersoga
    Apr 7, 2002
    1,630
    48
    UK
    +25
    Your dealer should be able to sort you out ;)
  3. robocop
    robocop
    Oct 16, 2000
    648
    Old Detroit a.k.a. Chippenham. Wilts
    +23
  4. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,570
    Edinburgh
    +1,268
    The mulit regio hack for the Dv29 is the same as for the older models like the DV88.
    1. Open disc tray
    2. Press '1111'
    3. Press '13'
    That's it.
