DV27A - sometimes the remote interprets buttons wrongly!
Discussion in 'Arcam Owners' Forum' started by cybersoga, Dec 18, 2004.
Tags:
  1. cybersoga
    cybersoga
    Apr 7, 2002
    1,630
    48
    UK
    +25
    The remote with my DV27A is a real pain in the arse. It takes a few goes of aiming it just at the right angle to get it to respond, and occasionaly it'll think I pushed a completely different button - for example, once I pressed the next chapter button and it thought I pressed menu. The demo unit I tried before I bought this one was just as bad so I don't think i'm the only one!
    PLEASE ARCAM! FIX MY REMOTE!
  2. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    On my DV88 PLus, I've always had the problem where hitting Status while watching a DVD often brings up the Setup screen instead. This happens with any reomote, and doesn't matter whether the remote is programmed thru learning or with discrete codes.
    I find this terribly annoying, but Arcam has said fixing this requires a firmware (rather than SW) update. I really wish they would fix this.
