DV27a question
Discussion in 'Arcam Owners' Forum' started by Jeff, Aug 4, 2004.
Tags:
  1. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    A question for the nice guys at Arcam, one anyone else that knows for certain.
    On a DV27a can I set the speakers to?;
    Front L/R = Large
    Centre = Not Present
    Surround L/R = Large
    Subwoofer = Not Present
    If I can do this, would I be right in saying the LFE and Centre channels get redirected to the Fronts and the surrounds remain unchanged?
    Thanks,
    Jeff
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    1: Yes it is possible to selct this configuration in the setup menu
    2: The centre channel sound will be redirected to the front left and right speakers in order to create a phantom centre channel.
    3: Ther rear speakers will function as normal, reproducing the full range of frequencies sent to them.
    4: The front left and right speakers will be sent the LFE information also which may cause them to bottom out sooner then expected.
  3. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    Thanks, thats what I thought.
