DV27A and Firmware
Discussion in 'Arcam Owners' Forum' started by highlander_777, Dec 11, 2004.
Tags:
  1. highlander_777
    highlander_777
    Apr 4, 2004
    216
    I recently bought the above DVD player
    I also checked the firmware and note that I am not running the latest release or am I. Now, I have Tag equipement also and one of the things I liked about Tag was the ability to download the firmware and load it up yourself. Also, when new releases were available a list also published outling enhancements and fixes
    I have looked on the ARCAM site and the above does not exist. Does anyone know if ARCAM will be offering such as service
    Finally, does anyone actually know what the latest is for the DV27A becuase my dealer did not actually know either.
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,259
    Rainham Essex
    +2,403
    I don't think Arcam will offer firmware upgrades via the web, but if you don't want to return your gear to a dealer to do the upgrade you can get them to request the software on a disk from Arcam on your behalf. They will then send you the disk on the understanding that the upgrade is done at your own risk.
    Or also at your own risk you can have a look Here for the updates.
    Mark.
  3. Mr THX
    Mr THX
    Nov 26, 2002
    1,295
    Barnsley
    +32
    How do you find out what firmware is on the machine out of interest ?? and what is the latest ??
    No worries I've found the information................. Ta.
  4. highlander_777
    highlander_777
    Apr 4, 2004
    216
    Check the link
    The latest release is 5.08 when I believe that latest is 5.13. I have 5.08 and was wondering what 5.13 offered :cool:
  5. Mr THX
    Mr THX
    Nov 26, 2002
    1,295
    Barnsley
    +32
    yep I checked the link and got the info.......... thankfully mine has 5.13 straight out of the box so I don't need to tinker.
  6. da95649
    da95649
    hi all,
    I have the old DV27 and I belive the firmware I have is 1.79, I dont fancy going all the way to my dealer as its a 3 hour drive!!
    Is there away where I can just upload the file via RS port at back, or maybe create a CD from an ISO that will update to the new firmware....in actual fact what is the latest firmware and the differences?
    Thanks all
    Darren
  7. robocop
    robocop
    Oct 16, 2000
    646
    Old Detroit a.k.a. Chippenham. Wilts
    +23
    da95649
    I do believe that v1.81 was that last update for the "old" Zoran 3 chipped DV27/DV88.
    I think that the the updates for the latest Zoran 5 chip DV27+ DV29 etc also include v1.81 also.
    I'm sure someone on here will confirm this, but you may want to look here.http://www.envytech.co.uk/arcamdvd/
