dv139 question
leon
Established Member
on the remote for the dv137 there is a hdmi button to browse through the resoulutions i.e 720 sd 1080i , is there a simular button on the dv139 remote (cr100) ??:rolleyes:
leon
Established Member
thanks can you change the modes from there ??
leon
Established Member
any ideas how do change it when you are viewing a film ? pressing the mode and shift only show me what res im on like 720p but can i change it without going into the setup menu every time thx :)
RadBadMark
Established Member
Yes, press SHIFT then MODE again! You need to press quickly though - first press displays the current resolution, subsequent presses will cycle through the different resolutions available.
Not sure what you mean by changing the modes from there - MODE button brings up the prologic settings, SHIFT and MODE cycles through the HDMI resolutions.
Hope that helps
leon
Established Member
thx for that it works a treat had to set it to auto in main menu:thumbsup:
SVS Prime Wireless Pro Powered Speakers - Review Coming Soon
