DV to US format VCD via Premiere? How do I do this?
I
ice9
Hi - having finally got my PC and Premiere 6 playing well together I'm ready to start the project which is getting footage of family over from the UK to our in-laws in the US. They are not computer savvy so I want to send it as VCD. So I have a JVC 767 which I can Firewire into my PC. What project settings should I be using in Premiere to start with? My plan is to then edit the footage, save it as MPEG and use Nero to burn a CD. Does the Terran EZ cleaner make suitable files for this or will I need to use TMPGEnc? If the latter then how should I save my file in Premiere before opening with TMPGEnc.
I'm quite au fait with all the editing processes in P6 - just am baffled by all the format options. Also feel free to point me in the direction of good reading material.
Prey + Bullet Train reviews, Heat 4K + Event Horizon 4K and all the latest movies and TV news
