E
eRat
I recorded girlfriend's gig with Panasonic NV-GS120 dv camera, used windows media player 10 with highest offered bitrate to save the files on comp. They use dvsd codec according to GSpot.
I'm planning on burning them on a dvd using tmpg(to convert it to format dvd player understands - Pal 4:3 - I live in Europe) and dvd lab to create animated menus, scenes and other stuff. I just started to learn both softwares. I also plan to have them in xvid format.
What bugs me is that when I play the video with pc all motion seems interlaced as in there are horizontal stripes where there is motion. Even slightest motion seems to generate those lines. I didn't notice them when I played it directly to television from DV camera. Is this related to de-interlacing? If so, should I deinterlace versions I am going to use in windows and leave the ones I plan one using in a home theathre interlaced? If not, is there anything I can do to get rid of the stripes? The quality is great otherwise and I assume it gets even better with noise reduction of tmpg.
I can povide a screenshot of the interlace effect if needed. I'm newbie with codecs, but I'd like to put together a nice dvd with some animated cg menus without too much hassle.
Any help greatly appreciated,
c & q
c & q
