J
jpawson8
Hi All
I am about to puchase a digi camcorder, probably the panasonic NVGS1B. Can this cam transfer the contents of the tape onto the PC. I clicked on a link which describes DV out.
Enables the camcorder to download still images to a home computer. Moving images can be downloaded with the appropriate software and hardware.
What software and hardware would I need to do this?
I can get this camcorder for £399. The Panasonic NVDS30B is £369 which has DV in. Which cam would you recommend. It's only going to be used for recording family clips.
I don't understand why you would want to record back to the tape using DV in? How do you play it?
Many Thanks
John
Many Thanks
John
