DV Mini tape purchase, help for a novice?
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by pzd, Mar 30, 2005.
  1. pzd
    pzd
    Mar 30, 2005
    38
    When I bought my Canon camcorder, there were three JVC DVM60ME tapes with it.
    I have been looking to buy further tapes and am a bit confused when I see DV and DVM in adverts. Is there a difference? If so what?
    I need tapes for 'one-off' use, I will record from camera, download to computer to make discs, and then store the tapes - not using them for 'over-recording'.
    Any suggestions as to what tapes I should buy, and from where?
    Thanks, in advance for any help.
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,132
    Rainham Essex
    +2,393
    Well I got my last batch of DV tapes from Here and their prices are the best I could find.
    I would recommend that you stick to the same tapes as you have been useing as different DV tapes have different coatingds that if they mix on the camcorders heads are likely to clog the heads causeing an expensive repair.
    there are a few different versions of DV tapes:
    MiniDV - the ones you have been useing
    MiniDV IC - have an IC chip to store details of the recordings. Not worth it as most consumer cams wont be able to use the IC chip.
    Then there are the pro version of full size DV & DVCAM tapes
    Anything labelled as MiniDV will be what you need. I would assume that the DVM relates to DV mini or just the product code of the make of tape.
    Mark.
  3. lurcher
    lurcher
    May 15, 2003
    4,114
    Stalybridge
    +202
    Mark,
    Thanks for the above link , great price on DV tapes so just placed order. Free del :thumbsup:
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,132
    Rainham Essex
    +2,393
    Yep, there are several cheap sites for DV tapes but you then get hit for expensive delivery. I found the site thanks to others recommending it on this forum.
    Mark.
  5. pzd
    pzd
    Mar 30, 2005
    38
    Thanks for the advice, Mark, always good to know someone out there can help a beginner.
  6. pzd
    pzd
    Mar 30, 2005
    38
    Been trying all day to open the link to 'discountdiscs', but cannot manage it! How did you manage, Lurcher?
    Had a look at 'Tape City', prices seem very keen - anybody used them?
  7. lurcher
    lurcher
    May 15, 2003
    4,114
    Stalybridge
    +202
    Just clicked on Marks link and it took me to site.
  8. pzd
    pzd
    Mar 30, 2005
    38
    Another day and still cannot get to the site from Mark's link (or even from the link sent to me after I emailed Discountdiscs).
    The computer just hangs until "cannot find server" appears.
    All my other 'browsing' is fine - so looks like I won't be able to use them.
    Thanks anyway! Cheers.
    Apologies, just tried using a different ISP and I got through OK - it seems that my 'Tesco.net' connection does not like the site! I will ask Tesco about it.
  9. Benfica
    Benfica
    I've emailed Sony (i've a Sony DCR-PC330 camcorder) asking about this and they answered me that there was no problem with my camcorder if mixing different mini DV tapes brands.
    So, i would e-mail canon, if I were you, to see what's their view on this issue.
    Now, if you are not confident about this, it's best to follow MarkE19 advice.
    HTH
