Dv In
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by technoant, Jun 19, 2004.
  1. technoant
    technoant
    Because my digital camcorder as only Dv out, would it be possible to edit my footage with either Pinnacle Studio 9 or Ulead Pro 7 on my PC ( fancy cuts and wipes ) and then send the edited footage over the PC firewire card to a stand alone DVD recorder that has a DV in connection? I am considering buying a standalone DVD recorder for this purpose as anyone tried doing this?
  2. Brian110507
    Brian110507
    Yes you should be able to do that satisfactorily.
    but don't get to carried away with the cuts and wipes they can ruin an otherwise excellent video - watch the way the proffesionals do it on TV except for music videos when it's done for effect there are virtually no wipes or fancy transistions to be seen.
  3. technoant
    technoant
    Thanks for the reply,
    One further question.
    There are many DVD recorders on the market with DV in, which way to go DVD+RW or DVD-RW Philips, Liteon and LG Etc, but the LG is currently on sale at my local Comet store £199.95 and DVD-RW and the one I am currently interested in, but cannot find a review and was trying to found out if somebody had sucessfully used there DVD recorder ( not PC DVD Writer ) DV in to record edited video and send it via the firewire card to the DV in connection on a Stand alone DVD Recorder?
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,353
    Rainham Essex
    +2,441
    IMHO DVD+RW or -RW is not really something to worry too much about. The vast majority of DVD players can play either format with the -RW just slightly more compatable. The chances are that if you have an old player that wont play one format then it is more than likely that it wont play any recorded DVD's.
    The other thing to ask you really is - Why do you want a standalone DVD recorder rather than an internal PC burner? If you will use the recorder to record from the TV then yes it is worth spending the extra money. But if all you want to do is record your footage from the PC then you can save a lot of money and get a PC burner for around £60 and most of these will record both the formats.
    The other advantage of going the PC route is that you can create far better looking menus and chapters than on a standalone recorder. All you need to do is get the software that can do what you want - and that costs from around £30, so not too expensive.
    Mark.
