DV In/Out
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by neil22, Jun 14, 2004.
  1. neil22
    neil22
    Can anyone please tell me the difference between a camera with DV out only and one with DV In/Out.
  2. Brian110507
    Brian110507
    If the camera has DV-out only you will be unable to send your edited masterpiece back from your PC to be saved on a brand new clean tape.
    You do this so that you have a first quality edited video if you need at any time in the future to copy your masterpiece for someone else to see and you have deleted all the original files off your PC in order to clear space on your hard drive.
    There is no other physical or operational difference in cameras having DV-out only or DV-in/out.
  3. neil22
    neil22
    Thanks very much, that has helped a great deal.
  4. technoant
    technoant
    Because my digital camcorder as only Dv out, would it be possible to edit my footage with either Pinnacle Studio 9 or Ulead Pro 7 on my PC ( fancy cuts and wipes ) and then send the edited footage over the PC firewire card to a stand alone DVD recorder that has a DV in connection?
  5. Brian110507
    Brian110507
    Yes you should be able to do that satisfactorily.
