DV-In enabling for JVC models - update
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by Mike Swannick, Oct 3, 2003.
  1. Mike Swannick
    Mike Swannick
    Having scoured the www, I came across the software and instructions on how to DV-In enable an number of JVC and Thomson camcorders, including my own model (GR-DVL30E).
    It required a data cable to be bought or built and instructions in English and other European languages.
    Well, I built a cable and followed the instructions........
    I am now the proud parent of a DV-In capable camcorder:clap: :clap: :clap: :clap:
    The software is fairly straight forward with options beyond what you need to accomplish this task.
    The cable cost less the £5.00 for the component parts from Maplins and 20 mins soldering time (depending on skill):confused:
    Father and camcorder are doing fine:smashin:
  2. torrent
    torrent
    Very good. Where did you find the software/instructions?
  3. Mike Swannick
    Mike Swannick
    Like the good and diligent web user that I am, I didn't record it! Sorry. However, it is a tiny little 66Kb Zip file if you want it?
  4. torrent
    torrent
    Doh!
    No, I don't need it but it might have been useful to some others, Seen a couple of posts recently regarding dv-in convertors.
  5. Mike Swannick
    Mike Swannick
    Found it.
    http://www.coastweb.de/dv/
    About half way down the page in the line that reads;
    Freeware DV-in program for JVC cams from Garfield - please upload mem dumps!
