DV enabling TRV140E
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by goldenfleece, Jun 3, 2002.
  1. goldenfleece
    goldenfleece
    Can anyone advise on availability of software to enable DV IN on the Sony CCD TRV140E digital 8 camcorder? I think this a new model and I cant see it listed on the compatibility charts of the DV enabling software on several web sites I have checked. Anyone know? Or is all the software in the Sony camcorders more or less the same anyway?
    Also, apparently on some Sony camcorders you get a manual white balance option appearing in the menu after DV enabling, and also analogue input is enabled via the line out socket. Would this apply to a 140E?
  2. DigiStuff
    DigiStuff
    Jan 22, 2002
    151
    Hi Golden,
    Sorry to tell you but you will not at the present time be able to enable this model of camcorder. This is because there is no LANC socket on that model, which is how you need to control the camcorder to make the change. Given time it might happen, keep an eye on this web site, www.datavision.co.uk.
    Best Regards,
    Mark T
