DV capture problem with Firewire hard drive
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by finnis, Dec 23, 2004.
  1. finnis
    finnis
    Dec 26, 2003
    79
    Bought myself a nice new Lacie 160gb external firewire drive for video editing purposes. When I tried to capture footage using imovie 2 (got a Mac) it told me the disk is too slow.
    This is weird as imovie 2 works perfectly with my internal drive, which is much slower in terms of both read and write speeds.
    I've freed up loads of space on my internal drive now (by copying loads of stuff to the lacie) so I can capture video OK and copy it across, but it kind of defeats the object.
    I'm puzzled. Any ideas anyone?
  2. Duncan Craig
    Duncan Craig
    Jun 1, 2003
    258
    The Grim North
    +17
    The best place to ask would be the iMovie forum on Apple site.
    But seeing as I'm here, check that your drive is formatted MAC OS Extended, I have two Lacie 200GB d2 drives and they run fine with all my Macs, but that's using Final Cut Pro.
    Another thing would be to try putting the drive and the camera on separate firewire ports.
  3. finnis
    finnis
    Dec 26, 2003
    79
    thanks, Duncan. I'll try the Apple forum. Heard good things about Final Cut Pro... is it as good as people say?
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,121
    Rainham Essex
    +2,388
    I've always seen it recommended to do this as the individual ports have their own throughput rather than the 2 devices sharing it and causing a bottle neck when the 2 devices are daisey chained.
    2 ports on a single firewire card is fine, you don't need 2 cards.
    Mark.
