dv camcorders
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by mulder, Sep 15, 2003.
  1. mulder
    mulder
    Dec 9, 2002
    146
    I have been searching high and low for a DV camcorder that suits my needs, and I finally found one the JVC GR-D50. It has DV/in and out plus analogue in but i cannot find any reviews for it. Does anyone know what it is like or failing that does anyone recommend a good budget DV camcorder for a simillar price £330-£400
  2. melliott1963
    melliott1963
    Nov 27, 2001
    427
    Ilford, Essex
    +4
    I always think you can't really go wrong with a Sony.
    For your price range, either the TRV14 or TRV19 should be fine. At www.ajelectronics.co.uk, these are going for £375.00 and £399.00 respectively, including postage.
  3. torrent
    torrent
    Go for the TRV19 as it has DV-in already enabled (the 14 is the 19 without the DV-in).
  4. mulder
    mulder
    Dec 9, 2002
    146
    The trv19 looks pretty good but will it allow me to copy some of my old vhs home video tapes to my pc.
  5. MarkE19
    MarkE19
    Aug 10, 2002
    17,354
    Rainham Essex
    +2,441
    Just had a look at the TRV19 on the Sony web site. There is no mention of AV-in, so I would assume you will not be able to use it to capture from your VHS.
    Mark.
