DV Camcorders With True 16:9?
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by Kevo, Aug 20, 2002.
  1. Kevo
    Kevo
    Aug 23, 2001
    5,448
    Manchester
    +166
    Do any of the current DV camcorders offer true 16:9 WS?
    I was in the market about a year ago but was dissapointed that there were none. This put me off.
    Has anything changed a year on?
    If 16:9 is going to be 'the standard' aspect ratio then I expect the camcorder I buy to do likewise.
  2. gmm
    gmm
    May 13, 2002
    112
    +3
    I don't believe there are any true 16:9 digital camcorders on the market at the mo, maybe some very expensive ones.
  3. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    I need a video camera as my HVC4000P is knackered and it is only 20 years old!
    Anamorphic Widescreen is a must and I will buy one when I find one!
  4. Matt F
    Matt F
    Jul 18, 2000
    900
    Chester, UK
    +4
    This article may help a bit:
    http://www.farnfilm.com/widescreen.html
    Incidentally, the camcorders he mentions that can do true 16:9 widescreen are in the £6K + price bracket!
    Many consumer level camcorders do offer widescreen or cinema modes that create either a letterbox or an anamorphic picture - my JVC DVP7 can do either. These modes are good fun to mess around with and the picture quality isn't that bad BUT at the end of the day it's a 4:3 image cropped top and bottom to produce a 16:9 image - you're not getting a wider picture at all you are just losing footage from the top and bottom - in short, you are getting less not more.
    One other issue, of course, is that if you do manage to record in anamorphic widescreen (using a true 16:9 camera, a lens attachment, or a cinema mode on a cheaper camcorder) then that recording's only going to be any use shown on a widescreen TV i.e. if you copy a recording to tape and lend it to someone else then they would need a widescreen TV to see it in the correct aspect ratio.
    Matt.
  5. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    Anyone I would ever lend a tape to would have a WS TV!
    My dad has a Hi8 with Anamorphic and the picture looks fine - just not up to DTTV/DVD standard.
    But better than Squash & Stretch or small picture in middle.
    L/B ok
    P/B not great!
  6. Matt F
    Matt F
    Jul 18, 2000
    900
    Chester, UK
    +4
    Yes but, assuming this is just a "widescreen/cinema" mode on your dad's camera, the picture he records is no wider than it would be if he recorded in 4:3 - basically the top and bottom of the picture are cropped and then some digital processing changes what's left into anamorphic.
    As I said, the results from my JVC are a lot better than I was led to believe when recording in anamorphic mode but the bottom line is that the quality is still inferior to the 4:3 mode and I am losing the top and the bottom part of the frame whilst gaining nothing in width i.e. it isn't widescreen - it's a cropped 4:3 image presented in anamorphic mode. Leave the camera in 4:3 and you'll get a better quality image and you won't lose anything from the top and bottom of the frame - what you do get, of course, is black bars at the each side when viewed on a widescreen TV.
    The only way to get proper widescreen (i.e. a wider picture than you can capture on a 4:3 camcorder) is:
    1. Spend £6K plus on a genuine 16:9 camcorder.
    2. Use an anamorphic lens attachment on a 4:3 camcorder.
    Matt.
  7. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    It may letter box on the chip but it still looks better than 4x3 on a widescreen TV.
    The recording is W/S enough - viewfinder shows vertically stretched people
    So what DV cams have this facillity?
