DV 88 Upgrade
Discussion in 'Blu-ray & DVD Players & Recorders' started by john R1, Jan 17, 2003.
  1. john R1
    john R1
    Nov 2, 2002
    692
    16
    essex
    Will the DVD-A Upgrade be available for the basic dv88 or only for the dv88+ i know you can upgrade the 88 to the 88+ but i dont need the prog scan at the moment await your replies John R1
  2. sounddog
    sounddog
    Dec 11, 2002
    3,373
    107
    Leicestershire, UK
    +461
    I can't find the relevant thread right now ... but there was a thread earlier in which (I believe) John Dawson of Arcam set out the options for upgrading a DV88 and (IIRC) he said that it would be possible to upgrade for DVD-A without having to upgrade to Prog Scan ... or if you had a DV88P then you could also upgrade without changing the Prog Scan option.
    Disclaimer : This is all from memory so if I'm wrong or misrepresented John Dawson then I appologise.
    Victoria
  3. Matt Horne
    Matt Horne
    Nov 20, 2000
    4,117
    83
    Over the Hill & Far Away
    +119
    Heres the options..
    For the DV88 you need to have the DVD-A upgrade board + the new AV board.
    Which means basically the new av board makes your machine a DV88+ and on top of this the DVD-A board is added. You will then have prog scan out of the box anyhow via the vaddis 5 chip. but there is a further option to add the SI prog scan board seperately if you so wish..
    Think thats about right!
    Please correct me if I am wrong
    Matt
  4. sounddog
    sounddog
    Dec 11, 2002
    3,373
    107
    Leicestershire, UK
    +461
    I hope I'm not breaking any rules here ... but this is the text from John Dawson when a similar question was asked previously - see thread http://www.avforums.com/frame.html?http://www.avforums.com/forums/showthread.php?s=&threadid=58125 .
    Victoria
