DV-79 and Pio 504HDE Problem
Discussion in 'Arcam Owners' Forum' started by LeeT, Jun 25, 2004.
Tags:
  1. LeeT
    LeeT
    Mar 24, 2004
    77
    Derby
    Anyone with the same setup have a problem when moving between R1 and R2 dvd's. The symptoms are that when a R1 disc is inserted after a R2 I often get sound out but just noise on the panel. Both the DVD player and plasma are set to Auto wrt PAL/NTSC. Sometimes simply pausing and re-playing corrects the problem, sometimes it fixes itself after 4 or 5 seconds of the disc playing.
    I have updated the player using 1111 13 whilst the drawer is open to multi-region.
    Anyone any ideas?
    Lee
