guido
Established Member
A few questions re the DV-575A...
Am looking for a DVD player to use with my SP4805 projector... currently have a Toshiba SD-330E which use with my Loewe Vitros and am very happy with it... now I can either move this to use with the projector and get another for the TV, or leave this one on the TV and get a new DVD player for the projector (they are in different rooms!).
So the questions...
1) How does the zoom work on the Pioneer. I like the Toshiba zoom a lot, when watching 1.85:1 movies, the first stage zoom on the Tosh basically expands the picture to almost 16:9 height and you lose the edges which is normally OK. How does the zoom on the Pioneer work?
2) Does the Pioneer play DVD+R disks? It only mentions -R in the specs. This will rule out the Pioneer completely.
3) The Pioneer has lots of picture tweaks... when adjusting the picture what do you do first... the projector or the DVD player using DVE Disk! From reading the excellent reviews on this site buy a member comparing the DV575 with the SD-340, it seems the 340 comes out of the box better, but the Pioneer is better after tweaking.
Now its £99 the 575 is closer to the SD340 and hence am considering it.
All replies greatefully received
Thanks,
Guido
So the questions...
Thanks,
Guido
