DV-575A DIVX HiRes scaling
Discussion in 'Blu-ray & DVD Players & Recorders' started by timc3, Feb 2, 2005.
  1. timc3
    timc3
    Feb 4, 2004
    56
    Stockholm
    Hi, I rendered last night a DIVX movie in HDTV format (1280*720) and it wouldn't play on my DV-575A. So I guess its unsupported, though the sound would play.
    Is there anyway of getting these players to scale it down and then play? Or do I have to use a PC for this?
  2. rickardl
    rickardl
    Sep 9, 2004
    686
    46
    Stockholm
    +127
    You'll need a DivX HD compliant player for that or use a PC.
    For DVDs and Divx/Xvid, the DV-575A will not display any resolution above
    720x576/480 but it will play the sound.
