Dusty Sony KP44PS2 ?
Discussion in 'General TV Discussions Forum' started by Graham Sims, Mar 15, 2003.
  1. Graham Sims
    Graham Sims
    Sep 30, 2001
    68
    Lincoln
    I've had my tv for about 18 months now and I am noticing dust on the inside of the screen.
    I have downloaded the service manual for it from the web, it tells you how to take the tv apart, could anyone give me any info on how to clean the inside of the screen, what I should use etc.
    Thanks,
    Graham
  2. jim.rae
    jim.rae
    No liquids of any kind - a clean dry anti static duster would be my choice.
    Or if you were careful, a vacuum cleaner hose with a very soft brush on the end - you don't want the dust to settle back inside the TV again before you seal it up...
