Dust under screen
Discussion in 'Headphones, Earphones & Portable Music' started by Chox1988, Jul 16, 2005.
  1. Chox1988
    Chox1988
    Mar 30, 2005
    16,792
    basingstoke
    +9,157
    Somehow dust is accumulating in the screen of my NW-HD1. Is there anyway to remove it.
    Cheers.
  2. Steven
    Steven
    Senior Moderator
    Feb 1, 2005
    37,221
    +6,428
    Take cover off? Although thats risky since D-pad is connected to the 'guts' by a cable.
    Suppose you'll have to get used to it....?
  3. alike
    alike
    i have little dots under the screen on my hd3, i don't know wether to take it back to the shop or not (only had it a few months)....do you think they would take it back?
  4. Mike_manchester
    Mike_manchester
    1) if it is noticable and distracting , then take it back under warrenty
    2) is it really dust or could it be a dodgy screen where some of the pixels have gone pop ? - You can test this by inverting the screen to black on white or whichever from the options menu - does the "dust" now stand out ?
    if so take it back under warrenty.
  5. magician
    magician
    Dec 27, 2004
    45
    I sent my HD3 back to Sony for the recall and it came back with a bit of fluff under the screen. I phoned Sony straight away and they apologised and said I could send it back for fixing.
    A few weeks later I got an invoice from Sony for a "no fault found" repair and an invoice for £15! Plus they withheld my HD3 until payment :(
    A couple of phone calls later i got the invoice cancelled and my HD3 back...fluff still in place. By this time i'd been without music for four weeks so I wasn't going to send it back again but it was frustrating that i returned a seemingly perfect (condition-wise) HD3 at Sony's request only for it to come back with a defect. :mad:
    My advice - live with the dust, but you could try a can of compressed air through some holes.
    Magic
    PS - my ipod arrives this week :clap:
