Dust Blobs (on a Z2)?
Discussion in 'Projectors, Screens & Video Processors' started by uczmeg, Dec 16, 2003.
  1. uczmeg
    uczmeg
    May 18, 2003
    3,433
    71
    Nottingham
    +52
    My friend has a Z2, he got a dust blob on his first day of viewing. I guess that will teach him for a messy bachelor pad! :rotfl:
    Will the retailer or the warranty do anything about this?
    I'm guessing not.
    What is the best way to get rid of it??
    Marc
  2. Off The Fence
    Off The Fence
    Nov 1, 2003
    308
    28
    North West London
    +91
  3. Mr_Belowski
    Mr_Belowski
    Mar 20, 2003
    777
    63
    Loughborough
    +281
    When I sent my Z1 back to Nexnix to correct a fault with the unit's PSU, they also gave the insides a clean, which got rid of a little dust blob that I'd learned to live with.
    Before taking a screw-driver to the unit, it's probably worth trying the retailer - depending on who it is, they might fix it for you
  4. Off The Fence
    Off The Fence
    Nov 1, 2003
    308
    28
    North West London
    +91
    I toyed with sending mine back to get it cleaned...
    Trouble is they do seem to build up naturally over time anyway (I have a rear projection LCD TV which I clean every 6 weeks or so), so I figured I'd do it myself to avoid being without 'my new best friend' :blush:
    I've had a couple more new ones accumulate on the Z2 since I gave it a clean out (although they're not as noticable at the 1st couple).
    I suspect it's just going to be one of those ongoing things you have to do regularly (take the dog for a walk, check the oil in the car, clean the Z2 panels... :rolleyes: )
    At least it's pretty straightforward.
    ...and no. I don't live in a particularly dusty environment...
    Ho Hum
  5. fred123go
    fred123go
    Sep 16, 2003
    1,044
    39
    Cobham, Surrey
    oh no i have a dust blob, my room isn't even dusty. I will follow those step by step guides, cheers paul, and hopefully all will be well.
    fred
  6. AV-Will
    AV-Will
    How big is your screen and how big is the dust blob fred? Good luck mate!
  7. fred123go
    fred123go
    Sep 16, 2003
    1,044
    39
    Cobham, Surrey
    6ft wide, and the blob is about 6cm in diameter, yeah if i screw this up i will be well ******. i just have to be careful thats all.
    cheers
    fred
  8. Off The Fence
    Off The Fence
    Nov 1, 2003
    308
    28
    North West London
    +91
  9. tomacwhite
    tomacwhite
    Oct 21, 2003
    234
    Midlands, UK
    +21
    My AE200 had a dust blob, and I was all set to open her up and clean it, but I was advised by another source to leave it for a while, and just hammer the projector for a good 5+ hour session. I did that, and the dust blob burnt itself out.
  10. Kane D Williams
    Kane D Williams
    Jan 24, 2002
    750
    Nr London
    +11
    Have any of you tried covering your Z2's up (with a bag or pillow case etc) when not in use? I did this with my last PJ and never had a dust blob!
  11. Kane D Williams
    Kane D Williams
    Jan 24, 2002
    750
    Nr London
    +11
    I'm going to get a canvas bag with draw strings made to cover my Z2 when ceiling mounted. It may look a bit crap, but the canvas material should not cause any dust of its own and hopefully work at treat?
  12. Paul D
    Paul D
    Dec 27, 2000
    2,737
    Manchester
    +534
    You can get draw string cloth bags for motor cycle helmets very cheap.
    I used one with my Toshiba MT1 and it worked a treat!:smashin:
