"Dust Aid" now I have a clean 30D sensor!
onefivenine
I just used 'Dust Aid' to clean my 30D sensor.
:D:D:D:D
It works!
It's easy!
No liquids involved! (ok I had a small sherry for dutch courage).
P.S. this is after 21k shots and counting, on an 18 month old 30D. (bought June 2006).
bowenjones
It certainly does look easy. Let us know if you have any problems with a higher than normal dust build up as I can't help but wonder if the pads would leave a slightly sticky residue on the sensor.
anthony.rowell
I clean my Sensor with a vacuum cleaner but not the house one but a mini one which they sell for cleaning the keyboard i have use it for three years with no problem this is where you will see them it was my idea to use it for the sensor as i cant see why you should blow the dust around better to suck it ! i get mine fron ebay now about £3 they drive of your computer USB it is easy to use i just hold it above the sensor cover works fine.cheers.Tony.
