DURAN DURAN new CD problems ipod
Discussion in 'Music & Music Streaming Services' started by paulefox, Oct 11, 2004.
  1. paulefox
    paulefox
    Feb 8, 2003
    1,343
    Bury St Edmunds
    +44
    I can not play this on my computer or import to Itunes , it imports but plays all jumbled up
    can anyone help , if this is copyright protection then it is pathetic as you can not play the music
  2. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    Take it back and exchange it
    If this is faulty play hell :mad: :devil:
  3. chrisebabey
    chrisebabey
    Sep 23, 2004
    34
    It is copy protected.
  4. paulefox
    paulefox
    Feb 8, 2003
    1,343
    Bury St Edmunds
    +44
    This kind of copy protection is out of order , I have purchased the music and should be able to play it on any machine I own
    I think I will take it back
    shame really I know this album has not had good reviews but I wanted to hear it
  5. StevieDvd
    StevieDvd
    Dec 27, 2003
    1,378
    Stevenage, Herts
    +151
    Does it play on a normal CD player?
    There are some MP3 rippers like EAC which may extract the music so you can record the WAVs back to a CDR or listen to them (or different file formats) on your PC.
    Had a similar problem with a Dido CD.
  6. coffee break
    coffee break
    Oct 31, 2003
    184
    +14
    I agree with the comments about this copy protection being wrong. I bought the CD yesterday and tried to rip it to my hardrive. No joy, it plays with a "stutter!". I used Exact Audio, then tried DB music convertor and then CDEX. None of them worked, all giving the same results! The only way to get this on your PC is to use the program supplied on the CD itself but this seems to compress the music (not what I want) and then only plays using their program as well! :thumbsdow If anybody finds a way round this please let me know. I want to be able to play the CD using winamp.
    SImon
