Dune Smart H1 replacement
Discussion in 'Digital TV & Video Players & Recorders' started by chalkstorm, Mar 18, 2018.
Tags:
  1. chalkstorm
    chalkstorm
    Jan 19, 2004
    433
    Rugeley
    +8
    Hi all
    The days of my dedicated cinema room are long gone (child plus Downsize!) but some elements of my set up remain .. Notably my monitor audio RS8s and Dune H1 box. I stream from a Synology setup to the box but while it plays stuff beautifully... There are more files that will play on my PC but not on the Dune so thinking it might be time for a replacement.
    Anyone point me in the right direction please? I'm a little out of touch to be honest. Don't want to spend a lot either!
    Si
  2. Ensor
    Ensor
    Nov 9, 2017
    472
    46
    Birmingham
    +141
    What files won't it play?
    I have the BD Prime 3.0, a slightly earlier model, and the only files it won't play are 3D .mkvs (big deal) or files encoded in H.265.
  3. chalkstorm
    chalkstorm
    Jan 19, 2004
    433
    Rugeley
    +8
    Good question..... Might be helpful if I was to understand that first! I think I'd assumed there were a few types but I'll check. I'm getting lots that it suggests the file is corrupt or there is no audio (but they play using VLC on my PC)
  4. Ensor
    Ensor
    Nov 9, 2017
    472
    46
    Birmingham
    +141
    Hmm, the only time I've seen the message suggesting the file may be corrupt is with a couple of ".wmv" files I've come across (music videos). It's a format that, like quicktime, I've always actively avoided though.
    I don't have VLC installed on any of my machines right now so I don't know what audio formats it supports. My guess would be that the files which play without sound have the audio encoded in a recent codec which the Dune doesn't support, like TrueHD/Atmos?
    If that's the case then yes you'll need a newer media player, though you could always get a copy of the file with a DTS or AC3 soundtrack instead.
  5. chalkstorm
    chalkstorm
    Jan 19, 2004
    433
    Rugeley
    +8
    Thanks Ensor. .. Very helpful. I'll take a better look at the files it doesn't like.
  6. Ensor
    Ensor
    Nov 9, 2017
    472
    46
    Birmingham
    +141
    Actually, what was I thinking there? Although the Dune won't decode some newer codecs, it should still be able to bitstream them to your TV or A/V amp.
    You can easily check what codecs your files use by using "Mediainfo". It's downloadable here: MediaInfo
  7. chalkstorm
    chalkstorm
    Jan 19, 2004
    433
    Rugeley
    +8
    Both of these files play on my PC.....
    So, this file plays but there is no audi no matter what I try on the Dune.
    Audio
    Format : AC-3
    Format/Info : Audio Coding 3
    Codec ID : 00002000-0000-0010-8000-00AA00389B71
    Duration : 1 h 42 min
    Bit rate : 448 kb/s
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 kHz
    Bit depth : 16 bits
    Compression mode : Lossy
    Stream size : 329 MiB (23%)
    Interleave, duration : 32 ms (0.77 video frame)
    ...and then this one comes up with "Error: file can't be played"
    Format : AC-3
    Codec ID : A_AC3
    Duration : 1 h 47 min
    Bit rate mode : Constant
    Bit rate : 448 kb/s
    Frame rate : 31.250 FPS (1536 SPF)
    Bit depth : 16 bits
    Stream size : 344 MiB (15%)
    Service kind : Complete Main
    Default : Yes
    Forced : No
  8. Ensor
    Ensor
    Nov 9, 2017
    472
    46
    Birmingham
    +141
    This one appears to have an incorrect Codec ID.
    That long string of numbers is a Windows GUID referring to a codec installed on the machine that encoded it. That'll be why the Dune can't make sense of it.
    That all looks OK to me, I'd be looking at the video codec on this one for the source of the error.
  9. a5ian300zx
    a5ian300zx
    Jun 14, 2005
    3,517
    2
    North London
    +423
