Dune max on gb network
Discussion in 'Video Streaming Boxes & Services' started by ngac, Jan 8, 2012.
  1. ngac
    ngac
    Nov 16, 2009
    458
    +9
    I have hp micro server, whs 2011 and dune max. On 100mb router streaming works a dream. On gb switch it stutters, anyone found solution for this?
    I thought it would be ok if I connected dune directly into 100mb router and server into gb switch but not so. Was hoping to keep server on gb if poss.. Plus worried if I ever upgrade router anytime soon I won't be able to get 100mb one!
    Any suggestions?
    Thanks.
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,441
    Rainham Essex
    +2,470
    What firmware do you have running on the Max?
    The latest beta firmware does seem to be causing a lot of users of Dune players to get stuttering. One suggestion has been that the Dune firmware doesn't get on with 'full duplex' and setting the NIC on the server to 'half duplex' may solve the stuttering, but at the cost of dropping back to 100mbps speeds for the server.
    You could also try rolling back to the last firmware if you do have the latest beta to see if that helps. I've not upgraded my Prime to the latest and it streams fine over a gigabit network.
    Mark.
  3. ngac
    ngac
    Nov 16, 2009
    458
    +9
    Yes I'm on latest. Gutted. Ill just leave on 100 and wait for next firmware update rather than roll back.
  4. HeadBanger
    HeadBanger
    Sep 22, 2000
    2,217
    Ashingdon
    +481
    Have you tried enabling the experimental GB support in the advanved Dune settings? Might be worth a try?
  5. ngac
    ngac
    Nov 16, 2009
    458
    +9
    nope will try that
  6. MarkE19
    MarkE19
    Aug 10, 2002
    17,441
    Rainham Essex
    +2,470
    I seriously suggest you don't try it - it will not work and is known to cause more problems than it was hoped it would solve. The Sigma 8642 just can't handle the processing required for gigabit throughput.
    IMO you are best ignoring this 'feature' totally.
    Mark.
  7. HeadBanger
    HeadBanger
    Sep 22, 2000
    2,217
    Ashingdon
    +481
    Mark I've had this on without any issues. It may solve the OPs problem so what's the harm in trying it? If it makes no difference or causes other issues then he can just switch it off again.
  8. MarkE19
    MarkE19
    Aug 10, 2002
    17,441
    Rainham Essex
    +2,470
    If anybody wants to try it then by all means do. I was just saying that I've never heard of anybody getting it to work reliably and when they have tried it tends to make the player unstable.
    Mark.
