dune hd smart h1 remote control code
Discussion in 'Video Streaming Boxes & Services' started by alex5908, Jul 13, 2015.
  1. alex5908
    alex5908
    Jul 13, 2015
    5
    4
    Canada, Ontario, Toronto
    Hello everybody,
    I bought a universal remote control but I can't set it up as I can't find the 4 digit code required for setting up my new universal remote control. Does anybody know this code?
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,602
    Rainham Essex
    +2,543
    Welcome to the forum alex5908 :hiya:
    Unfortunately the codes used for one universal remote may be very different to the codes used for another. So I doubt you will find a generic code for Dune players that will work with all universal remotes.
    I suggest you try a few codes or see if the remote has a learning feature where you use the original remote to teach the universal the correct ir codes.
    Or you might be lucky and find the required code at remote central (Google is your friend ;) ).
    Mark.
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,602
    Rainham Essex
    +2,543
    Another possibility would be to use an iOS or Android phone/tablet and their relevant apps - RC Applications
    Mark.
  4. alex5908
    alex5908
    Jul 13, 2015
    5
    4
    Thanks for the response. Which codes shall I try? Random?
    There's a learning function but I should program all the buttons one by one.
  5. alex5908
    alex5908
    Jul 13, 2015
    5
    4
    But I've already bought the remote control. Can I get the codes from the apps somehow?
  6. MarkE19
    MarkE19
    Aug 10, 2002
    17,602
    Rainham Essex
    +2,543
    The codes are hard programmed into a universal remote. If the make of the device you want to control is not listed then it is trial and error to try and find a working code.
    But if none work it is a matter of teaching the remote each button that you want to use.
    Mark.
