Dune HD Real Vision 4K (Dolby Vision File Playback Problem)
Ran into a problem today playing back a Dolby Vision file (refuses to play no error msg file state: no errors) and I was wondering if I post the mediainfo somebody might notice an issue and/or if anything sticks out:
General
Complete name : D:\file dumps\test.file.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (isom/mp42/dby1)
File size : 10.1 GiB
Duration : 57 min 14 s
Overall bit rate mode : Variable
Overall bit rate : 25.2 Mb/s
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main [email protected]@High
HDR format : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU
Codec ID : dvhe
Codec ID/Info : High Efficiency Video Coding with Dolby Vision
Bit rate : 24.4 Mb/s
Width : 3 840 pixels
Height : 1 608 pixels
Original height : 1 606 pixels
Display aspect ratio : 2.40:1
Original display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.165
Stream size : 9.77 GiB (97%)
Default : Yes
Alternate group : 1
Codec configuration box : hvcC+dvcC
Audio
Format : E-AC-3 JOC
Format/Info : Enhanced AC-3 with Joint Object Coding
Commercial name : Dolby Digital Plus with Dolby Atmos
Codec ID : ec-3
Bit rate mode : Constant
Bit rate : 768 kb/s
Maximum bit rate : 811 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 314 MiB (3%)
Language : English
Service kind : Complete Main
Default : Yes
Alternate group : 1
Complexity index : Not present / 16
Number of dynamic objects : 15
Bed channel count : 1 channel
Bed channel configuration : LFE
Text #1
Format : Timed Text
Codec ID : tx3g
Duration : 55 min 18 s
Bit rate mode : Variable
Bit rate : 59 b/s
Stream size : 23.9 KiB (0%)
Language : English
Forced : No
Text #2
Format : Timed Text
Codec ID : tx3g
Duration : 55 min 39 s
Bit rate : 66 b/s
Stream size : 26.8 KiB (0%)
Title : SDH
Language : English
Forced : No
Paramount + UK launch: Halo, Star Trek and Beavis, and all the latest 4K + Movie/TV News
