mtenga
Thanks for taking the time to look - much appreciated
Yes it is the same replacement plug that came with my Pro. Model PEL00852
That's great news! Thanks again for checking.Yes it is the same replacement plug that came with my Pro. Model PEL00852
Welcome to the club!@mtenga - well..... no response from Futeko - so I've taken the plunge and bought off of amazon.de
They only had 12 and were selling at one-a-day and so thought best to get in quick.
At £320 cheaper than the Zappiti Neo I couldn't justify buying the Zappiti.
I'm just hoping that Dune continue to mature their New GUI for the next 12 months to at least get to, but hopefully, surpass Zappiti's GUI (movie wall).
Not had a Dune for a long time - but I recall them being pretty rock-steady - especially the Dune H1.
If this is/going to be as bullet proof as previous models I'll be a happy customer - especially as it will only be used to play 3D, HD, 4K and MKVs movies plus TV series in MKV.
Is there a way to reorder the categories on the left hand side of the New GUI. My folders I have added are at the bottom. Would love them at the top....
I hope they add this feature.Not that I have seen but yes that would be handy.
They take feature requests. When or if they ever implement them is a completely different bowl of soup.I hope they add this feature.
Received the Dune Pro Vision 4K Solo today.
First impressions are great - took me a while to work out how to add my NAS' folders and then to scan. Overall the New Gui does nearly everything I want.
Now I can watch movies with full menus and the biggie for me - finally Dolby Vision on my LG OLED...whoop! whoop!
Anyone else getting audio not coming back immediately after pausing a video and then resuming it? Sometimes it only takes a few seconds, some times 10 or 15 seconds before audio comes back, even though the video starts right away. My receiver reports that there is no stream of data while this is happening. (I'm using Original (Bitstream) for my Audio setting). This is a problem unique to the Dune HD Max Vision 4K, earlier Dune players in a similar setup with the same settings and receiver never did this. Thanks.
This implies that my "library" or at least some meta-data about it is maintained by Dune outside of my home network. I'm ok with downloading meta-data for content, but I am hoping that my data is not pushed back to Dune.Sadly you do have to update the two players separately, unlike with Zappiti where you update the “account” once for multiple players. However, it’s no big deal because once you have confirmed association on the first Dune player the second will recognise this confirmation after you’ve done the identification on it. So the association is saved on the Dune database and that saves a bit of time on player 2.
On a scan after clear, MY Dune Real Vision incorrectly match’s the movie 13 (2010) to 13 Assassins (2010), despite each of these movies being both correctly named and each in own named folder and each folder having a correct NFO helper file. Is there a way to “help” the dune with its matching process?
Thanks, I realise that, however with 900 movies in correctly named+ (year) folders, the Dune scan is 100% confident it fully matched on only 50% of those, As I understand it the Dune should also read nfo files to improve match accuracy however IMO it doesn’t seem to use nfo, It would be helpful if we knew how the match algorithm works so as to help the Dune out!You can manually search/match movies. I don't recall the exact steps at this moment, but it's in the Collection Management.
Yes it’s supposed to read NFOs but I’ve heard it said it doesn’t. Nevertheless, the scraping is really very accurate. Of that other 50% of yours where it has not taken the extra step and confirmed association I bet the larger majority are still the correct movie. I almost never have to change a movie or TV show and find the performance of the scraper to be better than Zappiti and Kodi and different league to Zidoo. I’m 100% correctly matched on over 2000 movies and 130 TV series most with multiple seasons without any special naming convention beyond the bog standard.Thanks, I realise that, however with 900 movies in correctly named+ (year) folders, the Dune scan is 100% confident it fully matched on only 50% of those, As I understand it the Dune should also read nfo files to improve match accuracy however IMO it doesn’t seem to use nfo, It would be helpful if we knew how the match algorithm works so as to help the Dune out!
Yes, I tried the Dune Solo a few years ago but gave up, however the new Netflix like gui is very very nice and uniquely as afar as I know it now handles and dedupes multiple movie rips in the same folder (eg uhd, bluray, MKV) very smoothly plus nice movie set management too, so overall very Good, but troubled by some uhd iso glitches (DV related I think) but early days so they are limitedYes it’s supposed to read NFOs but I’ve heard it said it doesn’t. Nevertheless, the scraping is really very accurate. Of that other 50% of yours where it has not taken the extra step and confirmed association I bet the larger majority are still the correct movie. I almost never have to change a movie or TV show and find the performance of the scraper to be better than Zappiti and Kodi and different league to Zidoo. I’m 100% correctly matched on over 2000 movies and 130 TV series most with multiple seasons without any special naming convention beyond the bog standard.
Might not see much improvments in the near future with the recent events happening in Russia. Properly everything on hold for now..Have a Real Vision myself and don't see any glitches with any movie type including DV/Atmos. My HDD's are USB3 attached.
As a whole the FW is very stable and almost bug free. They are now concentrating on further improvements it seems.
Mine is via gigabit NAS, Are you playing back UHD ISO, DV 4K content, full menu?Have a Real Vision myself and don't see any glitches with any movie type including DV/Atmos. My HDD's are USB3 attached.
