oooo,thank you,it will be much learning as it looks like.Thank you again,i must go and explore more on dune hd.comIf it arrives just install the new alpha firmware which is rock solid and introduces you to the new Gui which is a nice upgrade and can easily be compared to the competition. At least is isn't as ugly as the Z
- New GUI
- New GUI
Hey but please tell how does unofficial or hacked version work?Because you have Dune you can tell the best about work,trick,apps and rest.Thank you in advantage!I tried to new dune gui and did not like it at all, seems like the focus is on streaming services which is rubbish as these boxes are not officially supported boxes so you have to have hacked/unofficial versions of apps. I wish they just focus on making it a good media player only as tired of these unofficial version of apps that stop working all the time.
If you want a streaming box then look at fire stick, Google tv, apple tv or nvidia shield etc. as they have official versions of software.
Thank you so much for precise description and pro and con.Thank you for your effort!Best regards!Here is the link to alpha firmware which include the new December one with change log, which I believe will be official this month.
- New GUI
Dune said they will also be releasing a new gui alpha firmware along side the release of the offcial firmware this month.I would not call it "rock solid", but it works for the most part. There are definitely glitches here and there.
It's been a while since the firmware with the NEW GUI has been updated. Hopefully it will be soon!
In general I have gotten used to and appreciate the ease of the new My Movies collection GUI.
Hopefully it will be easier/more configurable on a per-title basis to tweak things, but this is a fine start.
I am tempted to go to the new alpha December firmware but kind of like the new gui enough to stick with it...
Comparing it to the competition with Zi and Zap with there Beta version well then the Dune is rock solid with the Alpha Concerning the apps it's android same here they work much better then the competition . Netflix is known for making trouble for non official players otherwise i used it for testing and works fine for me . F1 Tv and other local brand new VRT app works flawlessly for me.I would not call it "rock solid", but it works for the most part. There are definitely glitches here and there.
Very useful,thanks!These are taken from the alpha firmware but will be included in the final release version.
The New Gui is the R18 branch, which will also have a new version.
R17 below
Changes:
- 1619DR models: Bugfix: More complete fix for DV/VS10 + DTS HD MA A/V desync problem.
- 1619DR models: Bugfix: BD3D support was broken.
- 1619DR models: Bugfix: Fixed the issue with rarely occurring random reboots.
- 1619DR/1619 models: Bugfix: ASS subtitles: technical tags could be wrongly shown.
- 1619DR/1619 models: Bugfix: Stuttering or skips on specific HLS streams (in particular DRM encrypted).
- 1619DR/1619 models: Bugfix: No audio in some Android apps after MUTE and in some other cases.
- 1619DR/1619 models: A/V sync correction is now remembered.
- 1619DR/1619 models: External subtitles: improved subtitle language recognition by filename.
- 1619DR/1619 models: Added support for "Favourites" button on the new "Dune Remote R3" Bluetooth remote.
- 1619DR/1619 models: DVD-Video: Optimized functions of some buttons (P+/P- can do FF/REW)
- 1619DR/1619/1395/1295 models: BD Menu: Bugfix: some scenes/logos wrongly displayed in a small window instead of full-screen.
- 1619DR/1619/1395/1295 models: BD Menu: Optimized functions of some buttons (P+/P- can do FF/REW, RETURN stops playback).
- 1395 models: Bugfix: Storage devices could be shown two times in some cases.
- All models: Bugfix: Sleep timer affected android apps in wrong way.
- All models: Bugfix: During playback, "D" button wrongly shown a message corresponding to an absent function.
- All models: Button "0" can now also be used to access "safe video mode" function on the main screen (in addition to "C", "REC", "MODE" buttons).
- All models: Repeat+shuffle improvements: added "repeat one" mode, added information in INFO block during playback, added IP control support (loop_mode=0/1/2, shuffle_mode=0/1), added possibility to auto-enable loop/shuffle by M3U tags (#EXT-X-PLAY-WITH-REPEAT, #EXT-X-PLAY-WITH-SHUFFLE).
- All models: For integrators: added supported for "locked" playback mode (which can be used for example with M3U files auto-started from Favorites) (details provided on request).
- All models: Netflix app: changed to a mobile version (TV version is not available any more because of Netflix policy), with various features for convenient controlling it via remote (more details: Dune Firmware Zone / Netflix ).
- All models: SmartTubeNext: changed to the stable version. If you prefer to use the beta version, disable the setting "Apps / Android apps / Use SmartTubeNext as YouTube", manually delete the stable app and install the beta app.
- All models: Minor other internal fixes and improvements.
- Vision models (RTD1619DR): new "Dune HD extensions for VS10" feature (improved picture quality, contrast and black levels when using Dolby Vision VS10 engine with SDR/HDR output). (How to use: enable VS10; set DV to Disabled when outputting SDR/HDR content to DV TV; keep picture adjustment settings at default values.)
If you update to the new Alpha you won’t lose the newer GUI. They are separate streams I think.In general I have gotten used to and appreciate the ease of the new My Movies collection GUI.
I agree that whilst it’s miles behind Zappiti and Zidoo it’s improved to the point where it’s a pleasurable use experience. Functionality wise it’s an accurate scraper and the “Cast and crew explorer” remains a killer feature. But they are staring from a low base and have a lot of catching up to do to the other two.
I was wondering if the GUI was separate or not - given the ease of firmware updating I may give it a try.
What really took me getting used to in the GUI (new or old) was using a traditional remote to find contextual menus. I have used jRiver Media Center for years, which is a full-on PC program (and quite excellent). I'd still be using it if not for Dune's EXCELLENT Dolby Vision support for BD/UHD backups, MKVs, etc. I still use jRiver for audio as I need to drive an external multi-channel DAC with full DSD support.
Anyone know where are Dune headquartered? Are they an Eastern European company? Chinese company? When I ordered mine several weeks ago, it took all of a few days for it to arrive in the US. I ordered it off one of their sites (I think European site?).
They way they have arranged it is that once you download the new GUI it is permanent. But you can always go back to the previous MyCollection via the settings. Downloading any other normal firmware has no effect on that.I was wondering if the GUI was separate or not - given the ease of firmware updating I may give it a try.
Dune are Russian, which is why you see Russian apps and posters, but of course all these players are initially manufactured in China. They have their HQ in Taiwan but really a Russian effort.
