Dumb question re: AV Amps/Receivers
Discussion in 'AV Receivers & Amplifiers' started by JoeyJoeJoe, Dec 10, 2003.
  1. JoeyJoeJoe
    JoeyJoeJoe
    Why do amps/receivers have inputs for a video signal? For instance, my Pio VSX-D912 has yellow sockets as well as reds and whites. I take it that the yellow would be for a composite video signal but why the need to route a video signal through your amp? Am I being stupid or am I missing the point somewhere?
  2. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,183
    2
    +3,641
    The S-VHS inputs are also there and do have their uses. Mrs Tons permits the use of a limited number of Games consoles at any one time- normally two. Now as my telly only has one S-Vid input, the amp acts as a switch for the two consoles. Further to this, when Mrs Tons is away, addtional consoles can be bought into play- normally using the front set of inputs to save a tortuous journey down the back.
