Dumb Question I Know
Discussion in 'Blu-ray & DVD Players & Recorders' started by sh18, Nov 29, 2004.
  1. sh18
    sh18
    Sep 5, 2004
    2,320
    Leicester
    +59
    Someone explain to me the ideas behind S-Video & Coaxial in terms of a dvd player?! stupid i know but i want to be clear on what it all means.
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    S-Video is a video output with much better quality than composite (yellow RCA connector), generally not as good as RGB though but often pretty close.
    NOTE: Composite, S-Video and RGB can also be carried via Scart-cables.
    'Coaxial' usually refers to the digital audio output (orange RCA connector) that uses a "digital" cable (75 Ohm impedance). Some DVD players have an optical digital output instead of a coaxial one while some models spot both.
    The digital outputs will stream the audio signal (PCM, DD or DTS) to an AV amp / receiver.
  3. phoebe
    phoebe
    This info is also useful for me. :thumbsup:
    Thank you Reiner...
