Dumb question I know, but.........
Discussion in 'Blu-ray & DVD Players & Recorders' started by Joti, Nov 27, 2004.
  1. Joti
    Joti
    Oct 30, 2004
    17
    4
    Hiya - I've just bought a Sony RDR-GX3 which I am going to archive VHS footage onto using DVD+RW and DVD-RW discs.
    My question is - are the recordings I make therefore Region 2, or are they not region encoded (Region 0?).
    Any help would be appraeciated! :thumbsup:
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,709
    Warwick
    +2,584
    All your recordings are Region free and will play on any player capable of playing PAL DVDs (and reading DVD-RW/+RW disks obviously).
    Note if your archiving you should really use DVD-R disks as these are more compatible than DVD-RW/+RW.
  3. Joti
    Joti
    Oct 30, 2004
    17
    4
    OK - thanks for that, Rasczak! ;-)
