Dumb Question ? HDMI/DVI or VGA on Pio434
Discussion in 'Desktop & Laptop Computers Forum' started by catdna, Jul 13, 2004.
  1. catdna
    catdna
    May 25, 2004
    44
    9
    Bicester, Oxon
    Hi All
    This is all still a bit new to me (the HTPC stuff) so I've just a couple of newbie questions.
    I've recently bought a Pioneer 434HDE and I'm looking to build a small HTPC to watch DVD's and DivX files. I'm a bit confused as to what would be the best video input type to use - I understand that DVI and HDMI are pretty much the same thing (except that HDMI carries sound too ?) - so how does that compare to a direct VGA connection from an HTPC ?
    Ideally I'd like to just setup the htpc to the default resolution of the screen (1024 * 768 * 75hz) and not have to worry about powerstrip etc - unless someone can enlighten me further ?
    Also, I presume that with the DVI / HDMI connection there's no need to worry about progressive scan (480/720 etc) ?
    Told you I was a newbie... and suggestions / tips most welcome !
    Chris
