Question Dumb question about GPU Power consumption
Discussion in 'PC Gaming & Rigs' started by PerfectBlue97, Mar 14, 2019 at 8:57 PM.
  1. PerfectBlue97
    PerfectBlue97
    Jul 15, 2010
    834
    28
    +51
    I'm looking to upgrade my Graphics card from a GTX 760 to a GTX 1660.
    I noticed that my existing GTX 760 needs 2 6-pin power adapters and it says that it requires 170W of power, but the GTX 1660 says that it only requires 120W of power.
    A newer more powerful card needing less power than my ancient 760?
    Is the GTX 1660 using less power because it's newer and more efficient, or am I misunderstanding the 1660's power requirements and it actually needs more power, or it gets other power from somewhere like the motherboard?
  2. drinkturps
    drinkturps
    May 20, 2006
    2,226
    116
    I cannot remember. Where am I? This kebab is cold.
    +774
    You almost answered your own question. It is more power efficient. Certainly when compared to older cards. It's a smaller card too compared to others so I'm guessing it does not need to slurp as much juice.
  3. andym81
    andym81
    Nov 13, 2016
    508
    28
    GB
    +91
    You've answered your own question :D
  4. PerfectBlue97
    PerfectBlue97
    Jul 15, 2010
    834
    28
    +51
    Yeah, but I needed to be sure.
  5. andym81
    andym81
    Nov 13, 2016
    508
    28
    GB
    +91
    I'm surprised it's that low to be honest mid range cards are normally 150w range
  6. PerfectBlue97
    PerfectBlue97
    Jul 15, 2010
    834
    28
    +51
    This was one of the reasons that I thought that I might have made a mistake. My ancient GTX 760 uses 170w and needs two 6 pin plugs, so I wasn't sure that I'd gotten the right numbers for this one. I think that it must simply be more efficient.
  7. andym81
    andym81
    Nov 13, 2016
    508
    28
    GB
    +91
    It makes sense when you consider the card will get 75watts from the pci slot and 50 from the power connector
