dumb component question...
Discussion in 'Cables & Switches' started by jabberwocky-, Oct 27, 2005.
  1. jabberwocky-
    jabberwocky-
    Jul 21, 2005
    247
    South East
    +4
    If i connect my dvd player to my telly via component, do I need an amp for the sound... or can running a sound cable from dvd player to tv work?
    Sorry for the rubbish question!
  2. Malky1903
    Malky1903
    Jul 2, 2003
    1,937
    48
    Aberdeen
    +64
    Red and white RCA/Phono cables will do just fine but you will only get stereo sound.
  3. Mad Mikeyboy
    Mad Mikeyboy
    Jun 23, 2004
    356
    Renfrew
    +12
    No such thing as a rubbish question....only rubbish answers!
    your components should be red,white and yellow. Red and white for audio and yellow for video :smashin:
  4. LFCRules
    LFCRules
    Sep 3, 2004
    2,682
    +188
    If you are using component cables, i.e. the Red/Green/Blue ones, you will need a seperate cable for sound. Component cables only carry video over the 3 cables. The yellow cable mentioned is for composite video, and you will need to use the red/white cables for that as well to get sound. If still unsure, post your kit and we'll try to help out.
    Andy
