Dumb Arse question, probably??, Digital Input
Discussion in 'Home Cinema Buying & Building' started by lettuce, Mar 25, 2005.
  1. lettuce
    lettuce
    Feb 19, 2005
    507
    +9
    Right, am quite new to the whole 5.1 surround sound scene. Have just gotten my self a Sony DAV-SA30 system, to watch DVDs, and play my PC & PS2 through! I Am a bit confused as to what a Digitial input is??? Is digital input the same as optical?, on the back of the sony it has 2 video inputs and 1 output, one set of these video inputs is labeled as 'Optical Digital In'. Now i though Optical was like the single wire cable, pictured here:
    http://shop.gameplay.co.uk/webstore...de=PT0527&title=joytech_digital_optical_cable
    But the connections for the 'Optical Digital In' on the back of the Sony are just the standard 3 AV sockets, Right (red), Left (white), and Video (yellow), not like the connect in link above??
    So whats the difference between 2?
  2. Strangerer
    Strangerer
    My PS2 only has 1 Digital Optical output and thats it, everything on mine goes out through the av multi output through a scart(are you sure you've got inputs on the back of yours? I could be wrong as mine is an older model). If you wanted to connect using an optical cable (for sound only) you have to remove the small square-ish cover and link the output on the back of the PS2 to an optical inputon your Sony DAV-SA30 .
  3. lettuce
    lettuce
    Feb 19, 2005
    507
    +9
    This is the thing, on the back of the DAV-SA30 its labeled as 'Optical Digital In', but its not the square cover type of connection its just the standard AV connections, right, left & video!!
    [​IMG]
  4. Strangerer
    Strangerer
    Strange. Definitely no optical connector there :confused:
  5. mjn
    mjn
    May 24, 2001
    17,984
    Herts, England
    +4,954
    I don't think that text should be there, especially since its the video section.
  6. lettuce
    lettuce
    Feb 19, 2005
    507
    +9
    Im starting to think the same, bloddy sony!, so what sound can i get through these AV inputs then?? Pro Logic, Pro Logic II, Surround???, but i guessing not Digital??
  7. wicket
    wicket
    Nov 23, 2004
    493
    Middlesbrough
    +10
    You cannot get an optical input, as you have guessed, because you don't have the correct optical input plug. There are two types of digital input - optical (black square plug) and coaxial (orange plug similar to a phono input).
    I don't bother having my PS2 set up optically because it is only advantageous if you are using it to run DVDs which have the 5.1 sound encoded on it. I don't believe there are many, if any, games encoded in 5.1 sound but it is a while since I have looked at the games (moved on to an XBox).
    Depending on the decoders in your Sony system you should be able to get Dolby Prologic as a minimum and Dolby Prologic II. These use the analogue signals to give a surround sound. You would need a scart connector that also has phono leads attached which you would then connect to your amp. Then you will be able to experience Dolby Prologic II sound (if the Sony has it) which will provide good surround sound for your games.
  8. lettuce
    lettuce
    Feb 19, 2005
    507
    +9
    At the moment i have My PC connected to one set of AV inputs, and the other set of AV inputs are connected to the TV via 2 AV outputs on the back of the TV! Would i still get the same quality of sound when playing my PS2, with the Sony DAV-SA30 hooked up to the TV rather than straight to the PS2? or would i only get Dolby Prologic and Dolby Prologic II, if the PS2 was hooked up to the amp rather than through the TV?
  9. wicket
    wicket
    Nov 23, 2004
    493
    Middlesbrough
    +10
    Anything you connect to your tv via scart leads will have its sound fed out through the phono outputs of the tv to the amp. You will not notice any loss in the quality of the sound and will be able to experience Dolby Prologic II.
