Due for Upgrade on TMOB. What phone?
Discussion in 'Mobile Phones Forum' started by colinb07958, Aug 3, 2006.
  1. colinb07958
    colinb07958
    Nov 20, 2005
    915
    28
    +44
    Hello
    I am due for a upgrade soon on my Tmobile contrac and as I have been with them for many years, they always give me great discounts.
    The question is what phone should I get upgraded to? I currently have Sony K750. I was looking at the MDA smart phones. Are they good?
  2. ma1234
    ma1234
    Jan 16, 2006
    667
    43
    +109
    Depends on what you want from a phone, the MDA series is really a PDA first with the phone functions second. As a result they do can take some getting used to although they do provide you with a platform to add your own software e.g. Tomtom (satnav) etc. If you just want a phone to make calls, text etc. then personally I wouldn't bother. The current crop is only has no 3G versions, the new models are due in the next couple of months or so.
