Dubbing on XS32
Discussion in 'Blu-ray & DVD Players & Recorders' started by AVFan7667, Dec 12, 2004.
  1. AVFan7667
    AVFan7667
    Nov 29, 2004
    170
    16
    I have had my XS32 for less than a week and am still getting to grips with everything it does.
    A couple of questions I can't seem to find in the manual (though it's not the easiest manual to find things in!) that I thought you very knowledgeable people might know the answers to.
    If I record to HDD in a fairly high bitrate, I have to do a Rate Conversion Dub to fit it on one disc when I want to burn it. I tried to do one of these tonight, and although it seemed to work (I cancelled it before it finished) it was in real-time - is this correct? If I want to rate-conversion dub a 4-hour title do I really have to wait 4 hours for it to finish?
    Also, when dubbing to DVD-RW, if the title doesn't fit on the disc, is it possible to have it automatically spread it over multiple discs without first rate-conversion dubbing it to fit on one?
  2. Mechman
    Mechman
  3. redsox_mark
    redsox_mark
    Oct 20, 2003
    6,512
    Bath, England
    +620
    No. You can create a playlist which splits your title in half, then dub the first half on one disc and the second half on the other.
    Mark
  4. Neville Street
    Neville Street
    Jul 11, 2004
    290
    +4
    As each recording can have a different record quality setting what I do is record stuff from the internal tuner that is not for archiving at about 4.6 and do Sky+ copy at 6.6. If I am copying from Sky+ and I know I will take out the ads and then put onto a DVD I set the quality at the right level for the final edit to fit on a disk. It becomes quite easy to do as you get used to it. I have had my Tosh for 5 months now and it is second nature.
    A useful feature that you may not have discovered is the "auto power off". In most time consuming activities, e.g. 4hr long rate convert, 6hr long Copy from Sky+, you press "quick menu" and then set to auto power off when done. I picked it up in use rather than from the manual.
  5. nunew33
    nunew33
    Jun 5, 2002
    1,736
    41
    Lytham St Annes, where people are put out to grass
    Quick menu...where would you be without it :D
  6. kocl
    kocl
    Jan 8, 2003
    602
    PORTUGAL
    +14
    Hi, i have a problem with dvd-r created with toshiba, Why does the menu key doesn0t work only the top menu?
