Dubbing in FR mode on Panny E85
Discussion in 'Blu-ray & DVD Players & Recorders' started by Mike Woods, Feb 4, 2005.
  1. Mike Woods
    Mike Woods
    Jan 25, 2005
    14
    Just recorded 1hr 40 mins worth of material on to my HDD. I tried dubbing it onto a DVD-R in FR mode, but the picture's awful and there's apparantly 30 mins worth of recording time in XP mode left on the DVD. What gives?
  2. bk8
    bk8
    Dec 24, 2004
    26
    3
    When I first got my E95 I read the guides and posts on the best ways of recording and archiving. It seemed best to record episodes/movies in FR following Rasczak's (forgive spelling if wrong) guide if the duration was already known.
    This means encoding once to HDD in FR mode and a high speed dub so should mean better picture quality.
    But then I noticed some unused space on DVD-Rs after high speed dubbing an FR mode recording from the HDD. And the PQ at times wasn't great.
    I now record everything to HDD in XP and then use FR dub to DVD-R and this has resulted in no wasted space and less artifacts in busy scenes (to me at least).
    Although this means encoding once in XP to HDD and again in FR to DVD-R I cannot tell the difference in PQ and am happy my disks get filled. I also don't worry anymore about calculating the duration of programmes.
  3. Nelviticus
    Nelviticus
    Jun 21, 2003
    468
    Hitchin
    +68
    It sounds like you mucked something up. When you dub in FR mode it should fill the whole DVD.
  4. bk8
    bk8
    Dec 24, 2004
    26
    3
    It does dubbing in FR from HDD to DVD-R.
    But not when say recording episodes in FR to the HDD then high speed dub from HDD to DVD-R. Maybe 1-200MB left unused maybe more.
  5. Mike Woods
    Mike Woods
    Jan 25, 2005
    14
    So, is it best to record from Freeview to HDD using XP mode, then dub to DVD in FR mode? Or should I record to HDD in FR than fast transfer to DVD?
    That's a lot of abbreviations!
  6. micke
    micke
    I'd say you in most cases should go for:
    HDD recording at XP
    DVD-R dubbing at FR
    It then doesn't matter if you HDD record e.g. 10 minutes prior/after the programme you want to record since you anyway can delete the unwanted parts.
    It takes a bit longer since you then have an extra real time recording (DVD-R dubbing) instead of a high speed dubbing, but I don't see this as a problem.
  7. Mike Woods
    Mike Woods
    Jan 25, 2005
    14
    micke,
    Wouldn't I then be losing quality because the prog was being encoded, and then encoded again?
  8. micke
    micke
    If you record 1 h 40 minutes to your HDD at XP and then DVD-R dub at FR I don't think you lose that much in quality compared to 1 h 40 minutes FR recording to HDD and then DVD-R dubbing at high speed, but...
    The risk can (maybe) also be that you "waste" some quality if the first HDD recording is not totally correct in time.
    With my eyes and my TV I have not noticed a significant difference between the two ways described above. Does anyone have another opinion?
  9. HMHB
    HMHB
    Nov 11, 2001
    25,516
    Nottinghamshire
    +3,852
    I'm sure that the one time I tried it I got some lip-synch problems. I dubbed from my Sky+ box onto the E85 HDD in XP mode and then used FR mode to burn to DVD after editing out all the adverts and stuff. It was the whole of the Paddy And Max series and I ended up redubbing from the Sky+ box onto the E85 in SP mode to give me 2 recordings of 80 mins each.
  10. Jules
    Jules
    Oct 11, 2000
    5,074
    +752
    Yeah, each run of encoding produces more and more lip-sync problems.
    One pass, i.e. FR mode to the HDD is not noticeable, but XP to the HDD and then FR to DVD-R should be avoided.
    In fact, as an experiment, I once tested this by recording to HDD, then to DVD-R, then back to HDD and finally back to DVD-R. The result was that voices were miles out of sync with the picture.
    I always high speed dub to DVD-R to avoid this problem.
    A good tip though is that although the panasonic will only allow 2 hours at SP mode to DVD-R, you can actually fit 2 hours 10 minutes by recording to HDD first and high speed dubbing afterwards.
    Since many films run just over 2 hours, this is very handy to know and produces better results than recording in FR mode for 2 hours 10 minutes.
