Hi all,
I'm looking at getting a dual tuner PCI Freeview card for my PC. It's a 3Ghz P4 with 1.5 gig of RAM and currently running Win XP Pro.
I want a card that will let me record two Freeview channels at once and not be affected by anything I might be doing on the PC at the same time (so ideally done in hardware rather than software).
I can spend upto £60 on this and have been looking at the Pinnacle PCTV Dual DVB-T Pro PCI and the Hauppage WinTV Nova-T 500 Dual Digital.
I was leaning towards the Nova-T, however have come across complaints of the card causing blue screening and also being too sensitive (momentary freezes on picture if there's a brief drop in signal strength). I already have a fussy DVD Recorder with Freeview that does this (but two Freeview boxes that don't!) so am keen to avoid another fussy device!
The Pinnacle sounds interesting but I have read some of the reviews online and found them to be less than glowing.
So, my question is what are the experiences of anybody who has either of these cards and, if they aren't good - can anybody recommend any alternatives for similar cost?
Regards
- Gord
Regards
- Gord
