Dual tuner DVB-T card??? Newb question.
Discussion in 'Desktop & Laptop Computers Forum' started by hamant, Apr 30, 2005.
  1. hamant
    hamant
    Mar 26, 2005
    16
    Hi, I'm just getting around to finishing my HTPC and need to get a tv card. I've been looking around for a DVB-T card with dual tuner, but can only seem to find this one. I would normally go for 2 cards, but i've got a shuttle system and only have 1 pci slot spare. I found this on google;
    http://www.mediaatlantic.com/product.php/48960/1529/
    Can anyone comment on this?
    I want something that will have the same features as the nebula card. IE. Dump the MPEG stream directly to the HD without any processing.
    Also, with a single tuner DVB-T card, what are the limitations? Can i record 1 channel and watch another? Or can i only either record or watch 1 channel at a time?
    Please help. :thumbsup:
  2. Rambles
    Rambles
    Jul 14, 2004
    8,489
    UK
    +1,357
    Interesting, not heard of that before, it says that it is MCE compatible but I didn't think MCE could cope with a mixture of tv cards, I thought you either had to have twin dvb-t cards or twin analogue cards otherwise the EPG and functionality will get confused.
    Hopefully someone else will know more...
    If you are looking for dual DVB-T tuners I have this USB2 box working within MCE, which you could use in addition to a PCI card to get the twin tuner functionality.
    Oh, and yes to watch one channel whilst recording another you do need two tuners.
  3. Skunkpipe
    Skunkpipe
  4. AV Junky
    AV Junky
    Oct 30, 2002
    1,214
    Staffordshire, UK
    +69
    A dual-tuner DVB card is under development at the moment. Is from the company that produces the "Black Gold" DVB card, if I recall. It is being specifically developed to answer a demand from Media Center PCs.
  5. Skunkpipe
    Skunkpipe
    indeed - I enquired about this a while back and was told to keep an eye out in 'April'. It can't be that far off now
  6. hamant
    hamant
    Mar 26, 2005
    16
    I sent an email to the people behind the Black Gold card asking about their dual tuner card and this is the reply i got;
    Dear Sir
    The Black Gold dual tuner product is scheduled for relaese in approx. 8-10 weeks. Unfortunately it will not support Top-up TV.
    Regards,
    Product Support
    Not sure if i can hold out.
  7. Slinkoff
    Slinkoff
    Oct 14, 2004
    699
    28
    +24
    I'm in exactly the same boat, only want to use 1 PCI slot but have dual digital tuner functionality. I emailed Black Gold and got the same response of April so it really can't be that far off. I think it's probably worth holding out for. I want to use my only other spare slot for a Mystique card: http://www.overclockers.co.uk/acatalog/HiTeC.html
    I want to make sure I'm not waiting for the wrong thing though. I'm currently not using my MCE2005 PC for TV, pending a tuner card. At the moment I just have a freeview settop box, no cable or sky or anything like that. Does that mean I need an analogue card rather than digital?
    I took analogue to mean plug the aerial in and you get the standard 5 channels and I understood DVB-T to mean, plug your aerial in and get Freeview digital channels. Is that not correct?
  8. Big Adam
    Big Adam
    May 7, 2003
    527
    Peterborough
    +4
    You are 100% correct.
  9. Fulltopuk
    Fulltopuk
    Oct 24, 2004
    407
    28
    +29
    I am no expert but will a Hauppage PVR 500 MCE do the job?
  10. Rambles
    Rambles
    Jul 14, 2004
    8,489
    UK
    +1,357
    It would do for analogue terrestial tv, or if you could feed it from two independent set-top boxes (e.g. either two freeview boxes, or two sky boxes)
